Conflict between fio.h and stdio.h (IAR)
1,937 次查看
razed11
Contributor V
If I include <stdio.h> and <fio.h> I get the error below. I'm using IAR and C++.
Error[Pe147]: declaration is incompatible with "extern "C" __interwork __softfp char *_io_fgets(char *, int32_t, mqx_file *)" (declared at line 189 of Freescale\Freescale_MQX_4_1/lib/frdmk64f.iar/debug/psp\fio.h") "C:\ C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.0\arm\inc\c\stdio.h 181
stdio.h defines:
__EFF_NR1    __ATTRIBUTES char * gets(char *);
and fio.h:
extern char       *_io_fgets(char *, _mqx_int, MQX_FILE_PTR);
Any advice on getting these to play well together?
Kenny
1,415 次查看
danielchen
The problem is that MQX already implements it's own  _io_fgets.  I think you can use MQX function, and not touch stdio.h to avoid conflict.
1,416 次查看
danielchen
