Compatibility imx219 and imx 93 frdm
Mathislt
I have an NXP IMX93 FRDM and I wanted to know if it is physically compatible with the imx219 camera?
Thank you in advance.
Rita_Wang
For The FRDM-i.MX93 board includes one MIPI CSI-2 camera interface with 2 data lanes and an FPC connector (P6) designed for camera modules.
NXP BSP supports MIPI CSI cameras, but IMX219 may require:
Device Tree changes for sensor driver.
V4L2 driver for IMX219 (often available in Linux kernel).
Mathislt
Ok thank you for your reply. But is the IMX219 camera physically compatible with the IMX93 FRDM board? Given that the board has 22 pins and the camera has 15 pins, I connected it using a 22-pin to 15-pin Raspberry cable.
Thank you in advance,
Mathis Le Thiec
Rita_Wang
A:YES.
%3CLINGO-SUB%20id%3D%22lingo-sub-2191360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECompatibility%20imx219%20and%20imx%2093%20frdm%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3EI%20have%20an%20NXP%20IMX93%20FRDM%20and%20I%20wanted%20to%20know%20if%20it%20is%20physically%20compatible%20with%20the%20imx219%20camera%3F%3CBR%20%2F%3EThank%20you%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Compatibility%20imx219%20and%20imx%2093%20frdm%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EBut%20is%20the%20IMX219%20camera%20physically%20compatible%20with%20the%20IMX93%20FRDM%20board%3F%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EA%3AYES.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Compatibility%20imx219%20and%20imx%2093%20frdm%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%2C%3CBR%20%2F%3EOk%20thank%20you%20for%20your%20reply.%20But%20is%20the%20IMX219%20camera%20physically%20compatible%20with%20the%20IMX93%20FRDM%20board%3F%20Given%20that%20the%20board%20has%2022%20pins%20and%20the%20camera%20has%2015%20pins%2C%20I%20connected%20it%20using%20a%2022-pin%20to%2015-pin%20Raspberry%20cable.%3CBR%20%2F%3EThank%20you%20in%20advance%2C%3CBR%20%2F%3E%3CBR%20%2F%3EMathis%20Le%20Thiec%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Compatibility%20imx219%20and%20imx%2093%20frdm%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%26nbsp%3BThe%20FRDM-i.MX93%20board%20includes%20one%20MIPI%20CSI-2%20camera%20interface%20with%202%20data%20lanes%20and%20an%20FPC%20connector%20(P6)%20designed%20for%20camera%20modules.%3C%2FP%3E%0A%3CP%3ENXP%20BSP%20supports%20MIPI%20CSI%20cameras%2C%20but%20IMX219%20may%20require%3A%3C%2FP%3E%0A%3CP%3EDevice%20Tree%20changes%20for%20sensor%20driver.%3C%2FP%3E%0A%3CP%3EV4L2%20driver%20for%20IMX219%20(often%20available%20in%20Linux%20kernel).%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
