Can anyone provide the LPDDR init code for K70?
889件の閲覧回数
pramodk_g_
Hi Everyone,
                          We are interfacing K70 with LPDDR (MT46H32M16LF – 8 Meg x 16 x 4 banks) and facing issues with our current configuration. Please let us know if there is any error in our configuration. Also it would be helpful if some one could provide us the correct LPDDR configuration.
Our configuration is as follows,
int ddr_init_script(void)
    if ((SIM_SCGC3 & SIM_SCGC3_DDR_MASK) != SIM_SCGC3_DDR_MASK)
        // Enable DDR clock gate
        SIM_SCGC3 |= SIM_SCGC3_DDR_MASK;
    else
        // Check to if the DRAMC is already initialized
        if ((DDR_CR00 & 1) == 1)
            return 1;
    // Setup drive strength & enable IO pad
    SIM_MCR &= 0xFFFFFF00;
    SIM_MCR |= 0x00000004;
    // Setup IO pad ODT, 700mV seperation & spare dly ctrl
#define DDR_PAD_CTRL    *((volatile unsigned long*)0x400AE1AC)
    DDR_PAD_CTRL = 0x00030203;
    SIM_MCR |= 0x100;    // DDR RCR reset
    SIM_MCR &= ~0x100;    // DDR RCR out of reset
    DDR_CR00 = 0x00000100;    // DDRCLS, start
    DDR_CR02 = 0x00007530;    // initaref, tinit
    DDR_CR03 = 0x01010707;    // tccd, wrlat, latgate, latlin
    DDR_CR04 = 0x07090201;    // trasmin, trc, trrd, tbint
    DDR_CR05 = 0x02000302;    // tmrd, trtp, trp, twtr
    DDR_CR06 = 0x01290404;    // intwbr, trasmax, tmod
    DDR_CR07 = 0x01010202;    // ccapen, ap, tckesr, clkpw
    DDR_CR08 = 0x06030300;    // tdal, twr, trasdi, tras
    DDR_CR09 = 0x020000c8;    // bstlen, nocmd, tdll
    DDR_CR10 = 0x03000002;    // trpab, tcpd, tfaw
    DDR_CR11 = 0x01000000;    // trefen, arefmode, aref, regdimm
    DDR_CR12 = 0x048a000b;    // tref, trfc
    DDR_CR13 = 0x00000005;    // pd, trefint
    DDR_CR14 = 0x00110002;    // txsr, tpdex
    DDR_CR15 = 0x0000000b;    // puref, sref, txsnr
    DDR_CR16 = 0x00000001;    // lpctrl, clkdly, qkref
    DDR_CR20 = 0x00030300;    // cksrx, cksre, lpre
    DDR_CR21 = 0x00000032;    // mr1dat0, mr0dat0
    DDR_CR25 = 0x0a010300;    // aprebit, colsiz, addpins, bnk8
    DDR_CR26 = 0x0101ffff;    // bnkspt, addcol, cmdage, agecnt
    DDR_CR27 = 0x00010101;    // swpen, rwen, prien, plen
    DDR_CR28 = 0x00000001;    // cmdlatr, bigend, reduc, csmap
    DDR_CR30 = 0x00000001;    // intack, rsyncrf
    DDR_CR34 = 0x00000101;    // odtwrcs, odtrdcs
    DDR_CR37 = 0x00000200;    // w2wsame, w2rsame, r2wsame, r2rsame
    DDR_CR38 = 0x00200000;    // p0wrcnt, pupcs, pdncs
    DDR_CR39 = 0x00000020;    // wp0, rp0, p0rdcnt
    DDR_CR40 = 0x00002000;    // p1wrcnt, p0typ
    DDR_CR41 = 0x01010020;    // wp1, rp1, p1rdcnt
    DDR_CR42 = 0x00002000;    // p2wrcnt, p1typ
    DDR_CR43 = 0x02020020;    // wp2, rp2, p2rdcnt
    DDR_CR45 = 0x00070b0f;    // p0pri3, p0pri2, p0pri1, p0pri0
    DDR_CR46 = 0x0f004000;    // p1pri0, p0prirlx, p0ord
    DDR_CR47 = 0x0100070b;    // p1ord, p1pri3, p1pri2, p1pri1
    DDR_CR48 = 0x0b0f0040;    // p2pri1, p2pri0, p1prirlx
    DDR_CR49 = 0x00020007;    // p2ord, p2pri3, p2pri2
    DDR_CR50 = 0x00000040;    // p2prirlx
    DDR_CR52 = 0x02000602;    // rddtenbas, phyrdlat, phywrltbs
    DDR_CR56 = 0x01030000;    // wrlatadj, rdlatadj
    DDR_CR57 = 0x01000000;    // odtalten
    DDR_CR00 |= 1;    // DDRCLS, start
    while ((DDR_CR30 & 0x400) != 0x400);
    // Setup memory address translation
    MCM_CR |= MCM_CR_DDRSIZE(0);
    return 1;
We created this configuration using this https://www.freescale.com/webapp/Download?colCode=KINETIS_K70_DDR_INIT&location=null&Parent_nodeId=&... tool.
Pramod
タグ(3)
485件の閲覧回数
soledad
The MQX BSP function that initializes SDRAM controller can be found in the source file
c:\Freescale\Freescale_MQX_4_x\mqx\source\bsp\twrk70f120m\init_hw.c.
_bsp_ddr2_setup
called by init_hardware() in the same file.
I attached the init for the mt46h32m16lf part. I hope this helps!!!!
Freescale also provides below application note about DDR2 SDRAM hardware design and initialization:
AN2910 (Hardware and Layout Design Considerations for DDR2 SDRAM Memory Interfaces) :
http://cache.freescale.com/files/32bit/doc/app_note/AN2910.pdf
AN3522 (DDR2 SDRAM on the ColdFire MCF5545x Microprocessor) : http://cache.freescale.com/files/32bit/doc/app_note/AN3522.pdf
Sol
486件の閲覧回数
soledad
_bsp_ddr2_setup
Sol
