I am user of MQX v4.0 and of Code warrior v10.2.
I am wroking on a project in which I need to use date_struct of mqx.h file for fill up the start time /date as well as to fill up End Time/Date on event. Now I required to calculate the duration between this two events time.
For example,
Struct DATE_STRUCT StartEventDateTime;
Struct DATE_STRUCT EndEventDateTime;
now i want this event duration between StartEventDateTime and EndEventDateTime.
Is MQX providing any function to calculate this duration??
I want to know the inbuilt function facility that is gives me duration.
I right now calculating this duration manually from Hour,Minute and Second.
Pls reply...
已解决! 转到解答。
 Carlos_Musich
			Carlos_Musich
		Hi Utsavi,
You can use following functions and manipulate the results to make the desired operation.
_ticks_to_time
_time_to_ticks
_time_diff
_time_diff_ticks
_time_from_date
_time_get
_time_get_ticks
_time_get_elapsed
_time_get_elapsed_ticks
and many other time functions that are described in MQX_Reference_Manual.pdf which is located in
C:\Freescale\Freescale_MQX_4_1\doc\mqx
Carlos
 Carlos_Musich
			Carlos_Musich
		Hi Utsavi,
_ticks_to_time
_time_to_ticks
_time_diff
_time_diff_ticks
_time_from_date
_time_get
_time_get_ticks
_time_get_elapsed
Carlos
