Build script of MQX4.1.1 for GCC improvement
794件の閲覧回数
gaetancarlier
May I suggest some imporvements to do on gcc buildscript/Makefile ?
When MQX is debugged using GDB (I use gcc-arm-none-eabi-4_8_3-2014q1 with GDB 7.6.0 as version GCC 4.8.3 seems to be the default version to build MQX 4.1.1), following error occurs:
_timer_create_component (...) at mqx/source/kernel/timer.c:241
(gdb) print KERNEL_TIMER
No symbol "KERNEL_TIMER" in current context.
This is due to optimizations done by GCC (even if optimlization level is set to 0 (-O0)).
By modifying mqx/build/<board>/make/tools/gcc_arm.mak, it is possible to solve this kind of error by replacing "-g2" occurrences by "-ggdb -g3"
After rebuilding all MQX and application, I have this:
$1=4
Gaëtan.
Message was edited by: Gaetan CARLIER
タグ(4)
688件の閲覧回数
danielchen
Hi Gaetan, thank you for sharing your solution in the community, I will reproduce it and submit a report if necessary.
Any time you think you find a bug I recommend to submit a Service Request at our web page www.freescale.com/support ,  technical support team can evaluate the case and report it to development team.
