Bug report: MQX 4.1 Linux build scripts.
955 次查看
billpringlemeir
All of the master Linux builds scripts use the following idiom,
$(cd path && ./build_gcc_arm.sh nopause)
The $() are not needed.  This is like $(echo ls).  Ie, the output of the commands (stdout) will be run as a command.  The lines should only be,
标记 (3)
805 次查看
soledad
Hi Bill,
It is always helpfully to receive customer’s feedback, thank you for your comment.
Sol
