Hi everyone,
I've used the BspCloningWizard program (from the <MQX instaldir>) to clone an example bsp to a new bsp (in the same <MQX instaldir>) and I modified the files as needed: I can work with the new bsp as expected.
Now I'd want to clone the cloned bsp to a newer bsp, but the cloned bsp isn't showed in the bsp list.
How can I use a cloned bsp as a starting point to another cloned bsp (i.e. how can I show the cloned bsp in the source bsp list)?
Many thanks
Teckna
Unfortunately cloning wizard does not currently support cloning already cloned bsp.
RadekS
