After creating a BSP with BSPCloningWizard I find myself wanting to run through the process again and adjust some parameters. Unfortunately this seems to be a one way street. It won't allow me to overwrite/delete a BSP of the same name, even after manually deleting references to my BSP in "config" and "mqx\source\bsp".
Can someone let me know what other references have to be deleted so the Wizard is happy?
PMT
已解决! 转到解答。
OK, I find that if I delete the .yml file in \tools\generator\records this does the trick.
My next question, is there an automated script to delete a generated BSP? The generator creates files everywhere!
PMT
