Does the BSP Porting Wizard tool still exist for MQX v5? If not, was it replaced by a new tool or is the expectation that the porting for a custom board will be performed manually?
Hi @BTaylor :
This tool was in CodeWarrior and does not exist any longer.
Porting from an evaluation board to custom hardware is done manually by the customer, or through Professional support.
