hello everyone,
I used the MQX 3.8 first , hope that get some guide or direct about my project.
my project is the SNMP management based on UDP (the realization of this function refer the MQX SNMP demo),and i need add the other function that get data from a uart port.
There are two major function in my project;
1: Send/Receive data to/from ethernet.( the communication between the PC and the development
board(MCF5225xEvb) )
2: Send/Receive data to/from uart .( )
Flow chart as:
The controller <---uart--> MCF5225x board <----ethernet----->PC
Now, i dont understand that how to add the uart interrupt in this demo(MQX SNMP) ?
I hope you can help me or give the correct direction to me;
Wati for your reply.
Thanks everyone
Solved! Go to Solution.
Hi Cathy,
I believe you will find the next appnote very useful:
http://cache.freescale.com/files/32bit/doc/app_note/AN4022.pdf?fsrch=1&sr=2
http://cache.freescale.com/files/32bit/doc/app_note/AN4022SW.zip?fsrch=1&sr=2
Hope this helps
-Garabo
Hi Cathy,
Hope this helps
-Garabo
NO one reply...
wait for continue...
Cathy!
We're very sorry for the delay, our tech department will shortly address your question.
Thanks for your patience!
Monica.
