Using TWR-SER2 with TWR-K70F120M for Ethernet
TWR-K70F120M running MQX and RTCS can work with the Dual Phy on TWR-SER2. Below I list the modifications I did to the default BSP:
1) I add phy_dp83xxx.c and phy_dp83xxx.h to the bsp_twrk70f120m build project. These files are with MQX in /mqx/source/io/enet/Phy
2) I modify the BSP to use DP83xxx PHY for the Ethernet MACNET:
in the /mqx/source/bsp/twrk70f120m/init_enet.c:
#include "phy_dp83xxx.h"
const ENET_IF_STRUCT ENET_0 = {
     &MACNET_IF,
     //&phy_ksz8041_IF,
     &phy_dp83xxx_IF,
     MACNET_DEVICE_0,
     MACNET_DEVICE_0,
     BSP_ENET0_PHY_ADDR,
     BSP_ENET0_PHY_MII_SPEED
3) MDIO line requires an external pull up resistor, per DP83849I Data sheet. As I didn't have one at the moment, I enable internal pull up on MCU pin PTB0.
in the /mqx/source/bsp/twrk70f120m/init_gpio.c:
//pctl->PCR[0] = PORT_PCR_MUX(4) | PORT_PCR_ODE_MASK; /* PTB0, RMII0_MDIO/MII0_MDIO   */
/* internal pull up enabled on MDIO */
pctl->PCR[0] = PORT_PCR_MUX(4) | PORT_PCR_ODE_MASK | PORT_PCR_PE_MASK | PORT_PCR_PS_MASK;
With these changes, the RTCS applications work over TWR-SER2 Dual PHY channel A.
On TWR-SER2, J8 and J9 are un-shunted, SW1 = 11000000, SW2 = 10100000
on TWR-K70F120M, J18 is configured to disable 50 MHz OSC, as I use 50 MHz clock source from TWR-SER2 U504 50 MHz output. This clock is used to provide reference clock for the MCU (EXTAL), as well as for the Dual PHY X1 input (RMII reference clock).
コメント
I had successfully run my Ethernet Driver on TWR-SER board for TWR-K70F120M but not working on TWR-SER2.
1. Is Ethernet Device in Single/Dual RMII mode is supported on TWR-SER2 board for TWR-K70F120M?  According to this link, (Line: 241) it is not supported?
2. If supported, then is there any change in signal settings like (MDC, MDIO, CRS_DV, RXDn, RXErr, TXDn, TXEN and RMII_REF_CLK) as compared to TWR-SER board?
I had made it work on BSP for TWR-K53N512, besides jumper settings listed above, I just applied changes mentioned in step 3.
Thanks and Best Regards,
Kan
Hi Hafiz,
I have successfully used TWR-SER and TWR-SER2 cards with MQX4.1 Ethernet applications for the TWR-K70F120M independently (i.e. only using one tower serial card at a time and not using both cards simultaneously).
Both TWR-SER and TWR-SER2 are running RMII and using the clock source from the respective TWR-SER(2) card to clock both the Ethernet PHY and the MCU which synchronizes the clock domains.
I can just swap the cards and run the same application code.
Note that when using the TWR-SER2 card I am only using one of the Ethernet ports ETH_A/J12.
David
%3CLINGO-SUB%20id%3D%22lingo-sub-1110006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETWR-SER2%20%E3%81%A8%20TWR-K70F120M%20for%20Ethernet%20%E3%81%AE%E4%BD%B5%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMQX%E3%81%8A%E3%82%88%E3%81%B3RTCS%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8BTWR-K70F120M%E3%81%AF%E3%80%81TWR-SER2%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABPHY%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEBSP%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%9F%E5%A4%89%E6%9B%B4%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1)phy_dp83xxx.c%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8A%E3%82%88%E3%81%B3phy_dp83xxx.hbsp_twrk70f120m%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%2Fmqx%2Fsource%2Fio%2Fenet%2FPhy%20%E3%81%AB%20MQX%20%E3%81%A8%E5%85%B1%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2)%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20MACNET%20%E3%81%AB%20DP83xxx%20PHY%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20BSP%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2Fmqx%2Fsource%2Fbsp%2Ftwrk70f120m%2Finit_enet.c%20%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_13754257705308064%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_13754257705308064%22%3E%0A%3CP%3E%23include%20%E3%80%8Cphy_dp83xxx.h%E3%80%8D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E5%AE%9A%E6%95%B0%20ENET_IF_STRUCT%20ENET_0%20%3D%20%7B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3BMACNET_IF%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%26amp%3Bphy_ksz8041_IF%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3Bphy_dp83xxx_IF%2C%3C%2FP%3E%0A%3CP%3EMACNET_DEVICE_0%E3%80%81%3C%2FP%3E%0A%3CP%3EMACNET_DEVICE_0%E3%80%81%3C%2FP%3E%0A%3CP%3EBSP_ENET0_PHY_ADDR%E3%80%81%3C%2FP%3E%0A%3CP%3EBSP_ENET0_PHY_MII_SPEED%3C%2FP%3E%0A%3CP%3E%20%7D%3B%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E3)%20MDIO%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81DP83849I%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81MCU%E3%83%94%E3%83%B3PTB0%E3%81%AE%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%2Fmqx%2Fsource%2Fbsp%2Ftwrk70f120m%2Finit_gpio.c%20%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13754258454794503%22%20jivemacro_uid%3D%22_13754258454794503%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3E%2F%2Fpctl-%26gt%3BPCR%5B0%5D%20%3D%20PORT_PCR_MUX(4)%20%7C%20PORT_PCR_ODE_MASK%3B%20%2F*%20PTB0%2C%20RMII0_MDIO%2FMII0_MDIO%26nbsp%3B%26nbsp%3B%20*%2F%3C%2FP%3E%0A%3CP%3E%2F*%20PTB0%2C%20RMII0_MDIO%2FMII0_MDIO%26nbsp%3B%26nbsp%3B%20*%2F%3C%2FP%3E%0A%3CP%3E%2F*%20MDIO%E3%81%A7%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E6%9C%89%E5%8A%B9%20*%2F%3C%2FP%3E%0A%3CP%3Epctl-%26gt%3BPCR%5B0%5D%20%3D%20PORT_PCR_MUX(4)%20%7C%20PORT_PCR_ODE_MASK%20%7C%20PORT_PCR_PE_MASK%20%7C%20PORT_PCR_PS_MASK%3B%20%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81RTCS%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFTWR-SER2%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABPHY%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABA%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETWR-SER2%20%E3%81%A7%E3%81%AF%E3%80%81J8%20%E3%81%A8%20J9%20%E3%81%AF%E3%82%A2%E3%83%B3%20%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%80%81SW1%20%3D%2011000000%E3%80%81SW2%20%3D%2010100000%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETWR-SER2%20U504%2050%20MHz%20%E5%87%BA%E5%8A%9B%E3%81%8B%E3%82%89%2050%20MHz%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81TWR-K70F120M%20%E3%81%A7%E3%81%AF%20J18%20%E3%81%AF%2050%20MHz%20OSC%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81MCU%20(EXTAL)%20%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20PHY%20X1%20%E5%85%A5%E5%8A%9B%20(RMII%20%E5%9F%BA%E6%BA%96%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%20%E3%81%AE%E5%9F%BA%E6%BA%96%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1110006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0TCPIP%E9%80%9A%E4%BF%A1%E3%82%B9%E3%82%A4%E3%83%BC%E3%83%88%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TWR-SER2%20%E3%81%A8%20TWR-K70F120M%20for%20Ethernet%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%8F%E3%83%95%E3%82%A3%E3%82%BA%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81TWR-SER%E3%81%8A%E3%82%88%E3%81%B3TWR-SER2%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92MQX4.1%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E3%80%81TWR-K70F120M%E7%94%A8%E3%81%AB%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%80%E5%BA%A6%E3%81%AB%201%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%83%AF%E3%83%BC%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3C%2FP%3E%3CP%3ETWR-SER%E3%81%A8TWR-SER2%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82RMII%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AETWR-SER(2)%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%BB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88PHY%E3%81%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E5%90%8C%E6%9C%9F%E3%81%99%E3%82%8BMCU%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%A6%E3%80%81%E5%90%8C%E3%81%98%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETWR-SER2%20%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%9D%E3%83%BC%E3%83%88%20(ETH_A%2FJ12)%20%E3%81%AE%201%20%E3%81%A4%E3%81%A0%E3%81%91%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDavid%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TWR-SER2%20%E3%81%A8%20TWR-K70F120M%20for%20Ethernet%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3ETWR-K53N512%20%E3%81%AE%20BSP%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E6%89%8B%E9%A0%86%203%20%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20TWR-SER2%20%E3%81%A8%20TWR-K70F120M%20for%20Ethernet%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3ETWR-SER%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%20TWR-SER%20%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8CK70F120M%20TWR-SER2%20%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E1.%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%2F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20RMII%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81TWR-K70F120M%20%E3%81%AE%20TWR-SER2%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%81%AE%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Flxr.missinglinkelectronics.com%2F%23uboot%2Fboard%2Ffreescale%2Fp1_twr%2Fp1_twr.c%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FA%3E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81(Line%3A241)%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E2.%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81TWR-SER%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81(MDC%E3%80%81MDIO%E3%80%81CRS_DV%E3%80%81RXDn%E3%80%81RXErr%E3%80%81TXDn%E3%80%81TXEN%E3%80%81RMII_REF_CLK)%E3%81%AA%E3%81%A9%E3%81%AE%E4%BF%A1%E5%8F%B7%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:11 AM
更新者:
