Porting a classic MQX RTOS Project to MQX RTOS for KSDK
Search instead for
No ratings
Many people has been asking about migrating from MQX RTOS to MQX RTOS for KSDK. Such guide is now available in the following link:
http://www.freescale.com/files/soft_dev_tools/doc/support_info/MQXKSDKPUG.pdf?fsrch=1
If you need to create a new MQX RTOS for KSDK project please note that there is not a New MQX for KSDK Project Wizard, therefore it is necessary to create it manually. You can find a guide in the link below.
How To: Create a New MQX RTOS for KSDK Project in KDS
Carlos Musich
Technical Support Engineer
Version history
Revision #:
1 of 1
Last update:
‎05-13-2015 01:11 PM
Updated by:
