Creating a New MQX RTOS 4.2 project in KDS
Hi everybody,
As there is not a New MQX 4.2 Project Wizard, it is necessary to create a project from scratch.
Here, we will create a new project making a copy from an example Project, for this example we are using FRDM-K64F120M but the process is similar for all the Freescale boards.
1. Import hello_frdmk64f example and just copy-paste it using Ctrl + C and Ctrl + V keys.
2. Delete the virtual folder to avoid editing the original file.
3. Create a New physical folder and named it Sources.
4. In Sources folder create a New Source file and name it main.c
5. Go to menu Project > Properties > C/C++ Build > Settings > Cross ARM GNU Assembler > Includes and delete all the paths.
6. Go to menu Project > Properties > C/C++ Build > Settings > Cross ARM C Compiler > Includes, delete all the paths and replace them with the following:
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\bsp\Generated_Code
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\psp
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\mfs
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\rtcs
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\shell
C:\Freescale\Freescale_MQX_4_2\usb_v2\<used_board>.kds\debug\usbh\mqx
${eclipse_home}../toolchain/lib/gcc/arm-none-eabi/4.8.4/include
${eclipse_home}../toolchain/lib/gcc/arm-none-eabi/4.8.4/include-fixed
${eclipse_home}../toolchain/arm-none-eabi/include
For the FRDM-K64F120M
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\bsp\Generated_Code
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\psp
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\mfs
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\rtcs
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\shell
C:\Freescale\Freescale_MQX_4_2\usb_v2\output\frdmk64f.kds\debug\usbh\mqx
Note: You can use  Ctrl + C and Ctrl + V keys.
7. Go to menu Project > Properties > C/C++ Build > Settings > Cross ARM C Linker > General and replace the linker file path with the following
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\bsp\intflash.ld
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\bsp\intflash.ld
8. Go to menu Project > Properties > C/C++ Build > Settings > Cross ARM C Linker > Miscellaneous and replace all Other objects with the following:
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\bsp\bsp.a
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\psp\psp.a
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\mfs\mfs.a
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\rtcs\rtcs.a
C:\Freescale\Freescale_MQX_4_2\lib\<used_board>.kds\debug\shell\shell.a
C:\Freescale\Freescale_MQX_4_2\usb_v2\output\<used_board>.kds\debug\usbh\mqx\libusbh_mqx.a
${eclipse_home}../toolchain/lib/gcc/arm-none-eabi/4.8.4/armv7e-m/fpu/libgcc.a
${eclipse_home}../toolchain/arm-none-eabi/lib/armv7e-m/fpu/libc.a
${eclipse_home}../toolchain/arm-none-eabi/lib/armv7e-m/fpu/libsupc++.a
${eclipse_home}../toolchain/arm-none-eabi/lib/armv7e-m/fpu/libm.a
${eclipse_home}../toolchain/arm-none-eabi/lib/armv7e-m/fpu/libnosys.a
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\psp\psp.a
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\mfs\mfs.a
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\rtcs\rtcs.a
C:\Freescale\Freescale_MQX_4_2\lib\frdmk64f.kds\debug\shell\shell.a
C:\Freescale\Freescale_MQX_4_2\usb_v2\output\frdmk64f.kds\debug\usbh\mqx\libusbh_mqx.a
9. Click to Apply and Ok buttons.
10. Go to C:\Freescale\Freescale_MQX_4_2\mqx\examples\hello and copy all the content in hello.c to main.c in your project
11. At this point you can be able to build and debug your New project. Enjoy...
コメント
There is no C:\Freescale\Freescale_MQX_4_2\lib\. What can i do? Also, i cant make TWR-K70* project in KDS because it is not supported, so which project do i have to copy?
Hello Martin,
First, you need to build the MQX libraries using KDS. Please find more information about Building MQX RTOS library and application project files in the
Getting Started with Kinetis Design Studio IDE and Freescale MQX™ RTOS document, this is located at the path: C:\Freescale\Freescale_MQX_4_2\doc\tools\kds
KDS supports k70 devices. Please import some mqx example located at the path: C:\Freescale\Freescale_MQX_4_2\mqx\examples
For example: C:\Freescale\Freescale_MQX_4_2\mqx\examples\hello\build\kds\hello_twrk70f120m
regards
Sol
Hello. After doing this and then building my project, I was not able to debug my application. When I selected 'Debug Configurations', my new copied project did not show up in the list. I am using the PEMicro debugging tools and am looking for my project's debug configuration under the 'GDB PEMicro Interface Debugging' section. Do you have any suggestions to fix this?
Thanks!
Could you please add a screenshot?
Sol
I am confused about something. I am a long time developer using Codewarrior 10.7 and MQX4.2 on MCF52259, however, new to the KDSIDE and Kinetis KL27.
Should I be using KDSIDE? or 10.7? Should I be using MQX from C:\Freescale\KSDK_1.3.0\rtos\mqx or direct from C:\Freescale\Freescale_MQX_4_2? There is no KL27 in MQX4.2...?
With the KDSIDE installation it appears there is its own version of mqx (in full or in part) C:\Freescale\KSDK_1.3.0\rtos\mqx\mqx\source as usually MQX source (at least with CW10.7 is C:\Freescale\Freescale_MQX_4_2\mqx\source? Can you explain the relationship here? Why is my board missing? are these lib's linked in some way?
I was trying to create a new "Hello Lite" project, I had built MQX in KDSIDE, but the above example reference MQX4.2 itself, not the KDS mqx... Looking at the link above the lite example is not part of MQX4.2 directory, only KDS rtos... There is also no KL27 example at all in MQX examples, again, only in KDS...
Hello Carl,
Unfortunately MQX 4.2 doesn't support KLxx devices and CodeWarrior doesn't support KSDK. If you want to use KL27 devices I suggest you to use MQX for KSDK or FreeRTOS and KDS IDE.
Have a nice day!
Soledad
Thanks... But how do I now go about making projects myself? there is no option? What are the differences between the two MQX versions? (what will i lose, what version is it?)
MQX Software Solutions are available in three variants to meet your embedded design needs: traditional MQX RTOS; MQX Lite; and MQX RTOS for Kinetis SDK (MQX for KSDK).
MQX RTOS for Kinetis SDK is the latest evolution of the proven and professionally developed  MQX™ Software Solutions for Kinetis MCUs. It is built on top of the software development kit (SDK) for Kinetis MCUs, leveraging the flexible and extendable peripheral drivers found within the SDK. MQX Lite configuration option is now available for enhanced scalability, allowing developers the option to use the same light weight kernel API found within MQX Lite RTOS.
MQX RTOS
MQX™ RTOS a full-featured complimentary real-time operating system including the MQX™ Kernel, TCP/IP stack (RTCS), embedded MS-DOS file system (MFS), USB host/device stack, and more. The MQX™ multitasking kernel provides pre-emptive scheduling, fast interrupt response, extensive inter-process communication and synchronization facilities. MQX RTOS includes its own peripheral drivers.
MQX Lite RTOS
 MQX™ Lite RTOS is a very light MQX™ kernel for resource-limited MCUs. Initially developed for the Kinetis L series family, it allows applications to run with less than 4 KB RAM. It is a true subset of the proven and professionally developed  MQX™ Software Solutions, allowing for easy upward code migration. It is easily configurable within Processor Expert Software to be used with the tool chain of your choice.
Please check the following document, this describes what is different in MQX for KSDK.
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/MQXKSDKPUG.pdf
In addition please check the below document, this is a guide that explains 2 different ways in order to create a New MQX for KSDK project in KDS
https://community.nxp.com/docs/DOC-103405
I hope this helps  :smileywink:
Thank you, that does clear up the differences.
However, the link you provided is confusing and jumps around a lot with looping references.
Can you point me to the exact documentation required to create my own hello world MQX lite and hello world MQX (standard) C project? The link you provided only has a C++ base board MQX project as far as I can find(and im not using C++).
For MQX-Lite: http://cache.freescale.com/files/32bit/doc/app_note/AN4610.pdf
Remember that MQX doesn't support  KL27 devices so you need to use MQX for KSDK.
Please check the attachment in How To: Create a New MQX RTOS for KSDK Project in KDS
HI Solead,
Sorry, I must be confusing the issue here.
I want to use the KSDK IDE and create my own C application using the KSDK MQX RTOS version (not codewarrior, not FSLMQX 4.2.2)
What you have provided (again) is normal MQX and Codewarrior (which I am using neither of), and the KSDK C++ project, which I am not using C++.
How do I create my own C code MQX RTOS for KSDK (NOT C++)
How do I create my own C code MQX Lite for KSDK (Not CW, Not MQX full version, not C++).
There are examples for the two above requests, but,t here is no way to create your OWN project.
Thanks.
G'day. I imported the files and changed the main but when I recompile the ELF file stays the same.
Am I missing something here?s
Edit : Disregard comment!
%3CLINGO-SUB%20id%3D%22lingo-sub-1115691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E8%A6%8F%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8C%E6%96%B0%E8%A6%8F%20MQX%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%BB%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%80%8D%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%9C%80%E5%88%9D%E3%81%8B%E3%82%89%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%20FRDM-K64F120M%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20Freescale%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%90%8C%E6%A7%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E4%BE%8B%3CSTRONG%3E%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97hello_frdmk64f%3C%2FSTRONG%3E%20%3CSTRONG%3ECtrl%20%2B%20C%3C%2FSTRONG%3E%E3%82%AD%E3%83%BC%E3%81%A8%3CSTRONG%3ECtrl%20%2B%20V%3C%2FSTRONG%3E%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3CSTRONG%3E%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%3C%2FSTRONG%3E%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20726px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56642iD7172E5DF4460DC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%85%83%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%B7%A8%E9%9B%86%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%AE%E6%83%B3%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_36.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_36.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55789i6C8F5C3150D48FBE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_36.png%22%20alt%3D%22pastedImage_36.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E6%96%B0%E3%81%97%E3%81%84%E7%89%A9%E7%90%86%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%20%3CSTRONG%3ESources%3C%2FSTRONG%3E%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%82%92%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%20style%3D%22width%3A%20797px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55821iE2F00A5CF8C0AF8C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_45.png%22%20alt%3D%22pastedImage_45.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.%20%3CSTRONG%3E%E3%80%8CSources%E3%80%8D%3C%2FSTRONG%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%80%8CNew%20Source%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%80%8C%3CSTRONG%3Emain.c%3C%2FSTRONG%3E%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%82%92%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20772px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54967i66887D9BCA1CF894%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E5.%20%3CSTRONG%3E%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%E3%80%8CProject%20%26gt%3B%20Properties%E3%80%8D%26gt%3B%E3%80%8CC%2FC%2B%2BBuild%20%26gt%3B%20Settings%E3%80%8D%26gt%3B%E3%80%8CCross%20ARM%20GNU%20Assembler%20%26gt%3B%20Includes%20%3C%2FSTRONG%3E%E3%80%8D%E3%81%AE%E9%A0%86%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_71.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_71.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55898i00B2043C8FAF531E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_71.png%22%20alt%3D%22pastedImage_71.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6.%20%3CSTRONG%3E%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%20%5BProject%20%26gt%3B%20Properties%5D%20%26gt%3B%20%5BC%2FC%2B%2B%20Build%20%26gt%3B%20Settings%5D%20%26gt%3B%20%5BCross%20ARM%20C%20Compiler%20%26gt%3B%20Includes%3C%2FSTRONG%3E%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cbsp%5CGenerated_Code%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cbsp%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cpsp%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cmfs%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Crtcs%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cshell%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Cusb_v2%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cusbh%5Cmqx%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Finclude%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Finclude-fixed%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Finclude%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EFRDM-K64F120M%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cbsp%5CGenerated_Code%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cbsp%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cpsp%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cmfs%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Crtcs%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cshell%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Cusb_v2%5Coutput%5Cfrdmk64f.kds%5Cdebug%5Cusbh%5Cmqx%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Finclude%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Finclude-fixed%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Finclude%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%89%8B%E8%A8%98%EF%BC%9A%3C%2FSTRONG%3E%3CSTRONG%3ECtrl%20%2B%20C%20%3C%2FSTRONG%3E%E3%82%AD%E3%83%BC%E3%81%A8%3CSTRONG%3E%20Ctrl%20%2B%20V%3C%2FSTRONG%3E%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_85.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_85.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55930iEDC5269485468003%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_85.png%22%20alt%3D%22pastedImage_85.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E7.%20%3CSTRONG%3E%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%20%5BProject%20%26gt%3B%20Properties%5D%20%26gt%3B%20%5BC%2FC%2B%2B%20Build%20%26gt%3B%20Settings%5D%20%26gt%3B%20%5BCross%20ARM%20C%20Linker%20%26gt%3B%20General%20%3C%2FSTRONG%3E%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cbsp%5Cintflash.ld%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM-K64F120M%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cbsp%5Cintflash.ld%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_106.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_106.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55655iB110BD9D0F2E282D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_106.png%22%20alt%3D%22pastedImage_106.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E8.%20%3CSTRONG%3E%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%20%5BProject%20(%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88)%5D%20%26gt%3B%20%5BProperties%20(%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3)%5D%20%26gt%3B%20%5BC%2FC%2B%2B%20Build%20%26gt%3BSettings%20(%E3%83%93%E3%83%AB%E3%83%89%20%E8%A8%AD%E5%AE%9A)%5D%20%26gt%3B%20%5BCross%20ARM%20C%20Linker%20(%E3%82%AF%E3%83%AD%E3%82%B9%20ARM%20C%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC)%5D%20%26gt%3B%20%5BMiscellaneous%20(%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FSTRONG%3E%20)%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20%3CSTRONG%3EOther%20%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FSTRONG%3E%20%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cbsp%5Cbsp.a%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cpsp%5Cpsp.a%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cmfs%5Cmfs.a%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Crtcs%3CSPAN%20style%3D%22font-family%3A%20'Segoe%20UI%20Symbol'%2Csans-serif%3B%22%3E%5C%3C%2FSPAN%3Ertcs.a%3C%2FP%3E%3CP%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cshell%5Cshell.a%3C%2FP%3E%3CP%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Cusb_v2%5Coutput%5C%3CSTRONG%3E%3CUSED_BOARD%3E%3C%2FUSED_BOARD%3E%3C%2FSTRONG%3E.kds%5Cdebug%5Cusbh%5Cmqx%5Clibusbh_mqx.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Farmv7e-m%2Ffpu%2Flibgcc.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibc.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibsupc%2B%2B.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibm.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibnosys.a%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM-K64F120M%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cpsp%5Cpsp.a%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cmfs%5Cmfs.a%3C%2FP%3E%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Crtcs%3CSPAN%20style%3D%22font-family%3A%20'Segoe%20UI%20Symbol'%2Csans-serif%3B%22%3E%5C%3C%2FSPAN%3Ertcs.a%3C%2FP%3E%3CP%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Clib%5Cfrdmk64f.kds%5Cdebug%5Cshell%5Cshell.a%3C%2FP%3E%3CP%3EC%3A%5C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%5CFreescale_MQX_4_2%5Cusb_v2%5Coutput%5Cfrdmk64f.kds%5Cdebug%5Cusbh%5Cmqx%5Clibusbh_mqx.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.4%2Farmv7e-m%2Ffpu%2Flibgcc.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibc.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibsupc%2B%2B.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibm.a%3C%2FP%3E%3CP%3E%24%7Beclipse_home%7D..%2Ftoolchain%2Farm-none-eabi%2Flib%2Farmv7e-m%2Ffpu%2Flibnosys.a%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E9.%20%E3%80%8C%20%3CSTRONG%3E%E9%81%A9%E7%94%A8%3C%2FSTRONG%3E%20%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%A8%3CSTRONG%3E%20%E3%80%8COK%E3%80%8D%3C%2FSTRONG%3E%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_119.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_119.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56016i72D864F9D52D6FCE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_119.png%22%20alt%3D%22pastedImage_119.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E10.%20%3CSTRONG%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Cmqx%5Cexamples%5Chello%3C%2FSTRONG%3E%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%20%3CSTRONG%3Ehello.c%3C%2FSTRONG%3E%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%20%3CSTRONG%3Emain.c%3C%2FSTRONG%3E%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_145.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_145.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F56409iE749972A8F5AE56B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_145.png%22%20alt%3D%22pastedImage_145.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E11.%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%E6%A5%BD%E3%81%97%E3%82%80%E3%80%82%E3%80%82%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%82%88%E3%81%AA%E3%82%89%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%86%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%82%82ELF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%90%8C%E3%81%98%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8B%E3%82%92%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B7%A8%E9%9B%86%3A%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F103405-12-293945%2FCreating%20a%20New%20MQX%20RTOS%20for%20KSDK1.2%20Project%20in%20KDS3.0.pdf%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F103405-12-293945%2FCreating%2520a%2520%E6%96%B0%E3%81%97%E3%81%84%2520MQX%2520RTOS%2520for%2520KSDK1.2%2520Project%2520in%2520KDS3.0.pdf%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F103405-12-293945%2FCreating%2520a%2520%E6%96%B0%2520MQX%2520RTOS%2520for%2520KSDK1.2%25...%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESol%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%BD%E3%83%AA%E3%83%BC%E3%83%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKSDK%20IDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81KSDK%20MQX%20RTOS%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3(codewarrior%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81FSLMQX%204.2.2%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AEC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C(%E5%86%8D%E3%81%B3)%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AEMQX%E3%81%A8Codewarrior(%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E7%A7%81%E3%81%8CC%20%2B%2B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84KSDK%20C%20%2B%2B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKSDK(C%20%2B%2B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E7%94%A8%E3%81%AE%E7%8B%AC%E8%87%AA%E3%81%AEC%E3%82%B3%E3%83%BC%E3%83%89MQX%20RTOS%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3EKSDK%E7%94%A8%E3%81%AE%E7%8B%AC%E8%87%AA%E3%81%AEC%E3%82%B3%E3%83%BC%E3%83%89MQX%20Lite%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B(CW%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81MQX%E3%83%95%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81C%20%2B%2B%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFor%20MQX-Lite%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fapp_note%2FAN4610.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fapp_note%2FAN4610.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fapp_note%2FAN4610.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMQX%E3%81%AFKL27%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81MQX%20for%20KSDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%80%8C%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211347%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22103405%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103405%22%20target%3D%22_blank%22%3E%E6%96%B9%E6%B3%95%3A%20KDS%20%E3%81%A7%20KSDK%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%94%A8%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FA%3E%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E9%81%95%E3%81%84%E3%82%92%E3%81%AF%E3%81%A3%E3%81%8D%E3%82%8A%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E6%B7%B7%E4%B9%B1%E3%82%92%E6%8B%9B%E3%81%8D%E3%80%81%E3%83%AB%E3%83%BC%E3%83%97%E3%81%99%E3%82%8B%E5%8F%82%E7%85%A7%E3%81%A7%E9%A0%BB%E7%B9%81%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E8%87%AA%E8%BA%AB%E3%81%AEhello%20world%20MQX%20lite%E3%81%8A%E3%82%88%E3%81%B3hello%20world%20MQX(%E6%A8%99%E6%BA%96)C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E9%99%90%E3%82%8A%E3%81%A7%E3%81%AFC%20%2B%2B%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89MQX%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%97%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AFC%20%2B%2B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EMQX%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E8%A8%AD%E8%A8%88%E3%81%AE%E3%83%8B%E3%83%BC%E3%82%BA%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB3%E3%81%A4%E3%81%AE%E3%83%90%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82MQX%E3%83%A9%E3%82%A4%E3%83%88%3B%E3%81%8A%E3%82%88%E3%81%B3Kinetis%20SDK%E7%94%A8%E3%81%AEMQX%20RTOS(MQX%20for%20KSDK)%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%3EKinetis%20SDK%E7%94%A8MQX%20RTOS%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%208.4pt%200in%208.4pt%200in%3B%22%3E%3CSPAN%3EMQX%20RTOS%20for%20Kinetis%20SDK%E3%81%AF%E3%80%81%E5%AE%9F%E7%B8%BE%E3%81%AE%E3%81%82%E3%82%8B%E5%B0%82%E9%96%80%E7%9A%84%E6%89%8B%E6%B3%95%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9FMQX%E2%84%A2%20Software%20Solutions%20for%20Kinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%E9%80%B2%E5%8C%96%E7%89%88%E3%81%A7%E3%81%99%E3%80%82Kinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88(SDK)%E3%82%92%E5%9F%BA%E7%9B%A4%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81SDK%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E6%9F%94%E8%BB%9F%E3%81%A7%E6%8B%A1%E5%BC%B5%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E5%BC%B7%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABMQX%20Lite%E6%A7%8B%E6%88%90%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AFMQX%20Lite%20RTOS%E3%81%A8%E5%90%8C%E3%81%98%E8%BB%BD%E9%87%8F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABAPI%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%3EMQX%E3%81%AERTOS%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%208.4pt%200in%208.4pt%200in%3B%22%3E%3CSPAN%3EMQX%E2%84%A2%20RTOS%E3%81%AF%E3%80%81MQX%E2%84%A2%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81TCP%2FIP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(RTCS)%E3%80%81%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFMS-DOS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(MFS)%E3%80%81USB%E3%83%9B%E3%82%B9%E3%83%88%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AA%E3%81%A9%E3%80%81%E3%83%95%E3%83%AB%E6%A9%9F%E8%83%BD%E3%81%AE%E7%84%A1%E6%96%99%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99%E3%80%82MQX%E2%84%A2%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%BB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%AB%98%E9%80%9F%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%BF%9C%E7%AD%94%E3%80%81%E5%BA%83%E7%AF%84%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E9%96%93%E9%80%9A%E4%BF%A1%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E5%90%8C%E6%9C%9F%E6%A9%9F%E8%83%BD%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MQX%20RTOS%E3%81%AB%E3%81%AF%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%3EMQX%20Lite%20RTOS%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%208.4pt%200in%208.4pt%200in%3B%22%3E%3CSPAN%3EMQX%E2%84%A2%20Lite%20RTOS%E3%81%AF%E3%80%81%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E9%99%90%E3%82%89%E3%82%8C%E3%81%9FMCU%E5%90%91%E3%81%91%E3%81%AE%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%BB%BD%E9%87%8F%E3%81%AAMQX%E2%84%A2%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E5%BD%93%E5%88%9D%E3%81%AFKinetis%20L%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E7%94%A8%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%814KB%E6%9C%AA%E6%BA%80%E3%81%AERAM%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%AE%9F%E7%B8%BE%E3%81%AE%E3%81%82%E3%82%8B%E5%B0%82%E9%96%80%E7%9A%84%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9FMQX%E2%84%A2%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%9C%9F%E3%81%AE%E3%82%B5%E3%83%96%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%8A%E4%BD%8D%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%82%92%E5%AE%B9%E6%98%93%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%20Software%E5%86%85%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMQX%20for%20KSDK%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsoft_dev_tools%2Fdoc%2Fsupport_info%2FMQXKSDKPUG.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsoft_dev_tools%2Fdoc%2Fsupport_info%2FMQXKSDKPUG.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsoft_dev_tools%2Fdoc%2Fsupport_info%2FMQXKSDKPUG.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81KDS%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84MQX%20for%20KSDK%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE2%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103405%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103405%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%AC%9D%E3%80%82%E3%80%82%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%87%AA%E5%88%86%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F2%E3%81%A4%E3%81%AEMQX%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F(%E7%A7%81%E3%81%AF%E4%BD%95%E3%82%92%E5%A4%B1%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%AB%E3%80%81%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81MQX%204.2%E3%81%AFKLxx%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81CodeWarrior%E3%81%AFKSDK%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82KL27%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81MQX%20for%20KSDK%E3%81%BE%E3%81%9F%E3%81%AFFreeRTOS%E3%81%8A%E3%82%88%E3%81%B3KDS%20IDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESoledad%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E9%95%B7%E5%B9%B4%E3%81%AE%E9%96%8B%E7%99%BA%E8%80%85%E3%81%A7%E3%80%81Codewarrior%2010.7%E3%81%A8MQX4.2%E3%82%92MCF52259%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81KDSIDE%E3%81%A8Kinetis%20KL27%E3%81%AF%E5%88%9D%E3%82%81%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKDSIDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%8210.7%E3%81%A7%E3%81%99%E3%81%8B%3FC%3A%5CFreescale%5CKSDK_1.3.0%5Crtos%5Cmqx%20%E3%81%AE%20MQX%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81C%3A%5CFreescale%5CFreescale_MQX_4_2%20%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%20MQX%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FMQX4.2%E3%81%ABKL27%E3%81%AF%E3%81%AA%E3%81%84...%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKDSIDE%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AEMQX%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEmqx(%E5%85%A8%E9%83%A8%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%80%E9%83%A8)C%3A%5C%20Freescale%20%5C%20KSDK_1.3.0%20%5C%20rtos%20%5C%20mqx%20%5C%20mqx%20%5C%20source%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99(%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82CW10.7%E3%81%A7%E3%81%AFC%3A%5C%20Freescale%20%5C%20Freescale_MQX_4_2%20%5C%20mqx%20%5C%20source%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%93%E3%81%A7%E3%81%9D%E3%81%AE%E9%96%A2%E4%BF%82%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%BD%A2%E3%81%A7%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%80%8CHello%20Lite%E3%80%8D%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AFKDSIDE%E3%81%A7MQX%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BE%8B%E3%81%AFKDS%20mqx%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FMQX4.2%E8%87%AA%E4%BD%93%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A9%E3%82%A4%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%AFMQX4.2%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81KDS%20rtos%E3%81%AE%E3%81%BF...%E3%81%BE%E3%81%9F%E3%80%81MQX%E3%81%AE%E4%BE%8B%E3%81%AB%E3%81%AFKL27%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%8F%E3%80%81%E3%81%93%E3%82%8C%E3%82%82KDS%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESol%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%8B%E3%82%89%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%5B%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%5D%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E6%96%B0%E3%81%97%E3%81%8F%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82PEMicro%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%5BGDB%20PEMicro%20Interface%20Debugging%5D%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Martin%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81KDS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20MQX%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%BC%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82MQX%20RTOS%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%80%8CKinetis%20Design%20Studio%20IDE%E3%81%8A%E3%82%88%E3%81%B3Freescale%20MQX%E2%84%A2%20RTOS%E5%85%A5%E9%96%80%E3%80%8D%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81C%3A%5CFreescale%5CFreescale_MQX_4_2%20doc%5Ctools%5Ckds%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKDS%20%E3%81%AF%20k70%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8Bmqx%E3%81%AE%E4%BE%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3AC%3A%5CFreescale%5CFreescale_MQX_4_2%5Cmqx%5Cexamples%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81C%3A%5CFreescale%5CFreescale_MQX_4_2%5Cmqx%5Cexamples%5Chello%5Cbuild%5Ckds%5Chello_twrk70f120m%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESol%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20KDS%20%E3%81%A7%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20MQX%20RTOS%204.2%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EC%3A%5CFreescale%5CFreescale_MQX_4_2%5Clib%5C%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%82%93%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81KDS%E3%81%A7TWR-K70*%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-08-2015 12:16 PM
更新者:
