(our development environment : MCU :MPC5604B, Compiler :windriver diab 5.5.1)
We have problem that when we compile project code from wind river diab 5.5.1 compiler
compiler has some errors (for example assembly error)
we think that the reason are makefile configuration or start up code problem (windriver doesn't understand code warrior start up code)
if you have experience that codewarrior compiler convert to wind river diab 5.5.1 compiler
(for example you have changed compiler configuration form code warrior eclipse program (named :CW for MCU V10.7)
please advise about our problem
thank you for your reading time
If I understood you correctly you want to use CW startup in Windriver compiler.
You cannot just overtake it as there is different syntax.
You have to port it to Windriver.
Or you have to ask Windriver for their startup.
Peter
