why is the SPC5748G's RESET Pin low-level all the time, when core voltage is 1.25V?
The chip was downloaded successfully once, and then the chip download fails, the reset pin appears low-level all the time!
解決済! 解決策の投稿を見る。
Check if reset is right after Power on Reset low.
If yes then you have brick device by programming ECC error into HSM flash block.
I recommend you to not program HSM flash block at all.
We have already many threads on this here on community.
Peter
Peter
