I see an example of the changes start.c。I generated the RAM .map file.
Link map of __start
1] __start (func,global) found in __start.o
1] >>> UNREFERENCED DUPLICATE __start
1] >>> (func,global) found in Runtime.PPCEABI.VS.UC.a __start.o
2] __init_registers (func,weak) found in __start.o
2] >>> UNREFERENCED DUPLICATE __init_registers
2] >>> (func,weak) found in Runtime.PPCEABI.VS.UC.a __start.o
3] _stack_addr found as linker generated symbol
3] _SDA2_BASE_ found as linker generated symbol
3] _SDA_BASE_ found as linker generated symbol
2] __init_hardware (func,global) found in __ppc_eabi_init.o
2] __init_data (func,weak) found in __start.o
2] >>> UNREFERENCED DUPLICATE __init_data
2] __init_user (func,global) found in __ppc_eabi_init.o
3] FlashConfig (func,global) found in __ppc_eabi_init.o
4] @22 (object,local) found in __ppc_eabi_init.o
2] main (func,global) found in main.o
3] num (object,global) found in main.o
3] CANA_i (object,global) found in main.o
3] CANAlen (object,global) found in main.o
3] CANAdummy (object,global) found in main.o
3] sp_FlashPageAddr32 (object,global) found in main.o
3] ECCErrPageAddr (object,global) found in main.o
3] FLAG_ThisBlockCanntErase (object,global) found in main.o
3] Data_bufCount (object,global) found in main.o
3] PageCounter (object,global) found in main.o
3] PageInterCount (object,global) found in main.o
3] one_fourth_Page_32b (object,global) found in main.o
3] Data_buf (object,global) found in main.o
3] FlashStartAddr (object,global) found in main.o
3] Data_bufTotalNum (object,global) found in main.o
3] PageTotalNum (object,global) found in main.o
2] exit (func,weak) found in __ppc_eabi_init.o
3] _ExitProcess (func,weak) found in __ppc_eabi_init.o
1] INTC_INTCInterruptHandler (func,global) found in IntcInterrupts.o
1] EXCEP_DefaultExceptionHandler (func,global) found in Exceptions.o
1] @102 (object,local) found in main.o
2] @101 (object,local) found in main.o
1] @6 (object,local) found in Exceptions.o
2] @5 (object,local) found in Exceptions.o
1] @13 (object,local) found in IntcInterrupts.o
2] @12 (object,local) found in IntcInterrupts.o
1] __init_cpp_exceptions_reference (object,global) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
2] __init_cpp_exceptions (func,global) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
3] fragmentID (object,local) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
3] __exception_info_constants (func,weak) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
4] _eti_init_info (object,global) found in Linker Generated Symbol File
3] __register_fragment (func,global) found in Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
4] fragmentinfo (object,local) found in Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
3] __restore_frame_and_exit (func,global) found in Runtime.PPCEABI.VS.UC.a runtime.o
1] __fini_cpp_exceptions_reference (object,global) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
2] __fini_cpp_exceptions (func,global) found in Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
3] __unregister_fragment (func,global) found in Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
1] _ctors (notype,global) found in Linker Generated Symbol File
1] _ctors$99 (object,global) found in Linker Generated Symbol File
1] _dtors (notype,global) found in Linker Generated Symbol File
1] _dtors$99 (object,global) found in Linker Generated Symbol File
3] .text (section,local) found in main.o
3] .text.110 (notype,local) found in main.o
3] .init (section,local) found in __start.o
3] .init.79 (notype,local) found in __start.o
3] .text (section,local) found in Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
3] .text.1683 (notype,local) found in Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
3] .text (section,local) found in Runtime.PPCEABI.VS.UC.a runtime.o
3] .text.205 (notype,local) found in Runtime.PPCEABI.VS.UC.a runtime.o
.init section layout
Starting Virtual File
address Size address offset
.init_vle section layout
00000000 00000c 40000000 000001a0 1 .init __ppc_eabi_init.o
00000000 00000c 40000000 000001a0 2 __init_hardware __ppc_eabi_init.o
UNUSED 000022 ........ ........ __flush_cache __ppc_eabi_init.o
0000000c 0000cc 4000000c 000001ac 1 .init __start.o
0000000c 0000b0 4000000c 000001ac 4 __start __start.o
UNUSED 00003c ........ ........ __copy_rom_section __start.o
UNUSED 000028 ........ ........ __init_bss_section __start.o
000000bc 00001a 400000bc 0000025c 2 __init_registers __start.o
000000d6 000002 400000d6 00000276 2 __init_data __start.o
000000d8 000000 400000d8 00000278 1 .init.79 __start.o
000000d8 00000e 400000d8 00000278 1 .init Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
000000d8 00000e 400000d8 00000278 2 __exception_info_constants Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
UNUSED 000028 ........ ........ __find_exception_addresses Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
.__exception_handlers section layout
00000000 000002 40001000 00000290 1 .__exception_handlers Exceptions.o
00000000 000002 40001000 00000290 16 EXCEP_DefaultExceptionHandler Exceptions.o
00000002 00000e 40001010 000002a0 16 *fill*
00000010 000096 40001010 000002a0 1 .__exception_handlers IntcInterrupts.o
00000010 000096 40001010 000002a0 16 INTC_INTCInterruptHandler IntcInterrupts.o
.text section layout
.text_vle section layout
00000000 000c44 40002000 00001000 1 .text main.o
00000000 000c44 40002000 00001000 2 main main.o
00000c44 000000 40002c44 00001c44 1 .text.110 main.o
00000c44 000064 40002c44 00001c44 1 .text __ppc_eabi_init.o
00000c44 00003c 40002c44 00001c44 2 FlashConfig __ppc_eabi_init.o
00000c80 000012 40002c80 00001c80 2 __init_user __ppc_eabi_init.o
00000c92 000014 40002c92 00001c92 2 exit __ppc_eabi_init.o
00000ca6 000002 40002ca6 00001ca6 2 _ExitProcess __ppc_eabi_init.o
00000ca8 00003a 40002ca8 00001ca8 1 .text Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000ca8 00001e 40002ca8 00001ca8 2 __register_fragment Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000cc6 00001c 40002cc6 00001cc6 2 __unregister_fragment Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00005a ........ ........ ExPPC_FindExceptionFragment__FPcP12FragmentInfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 0000e2 ........ ........ ExPPC_FindExceptionRecord__FPcP15MWExceptionInfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000006 ........ ........ ExPPC_PopR31__FPcP15MWExceptionInfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000012 ........ ........ ExPPC_CurrentAction__FPC14ActionIterator Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000168 ........ ........ ExPPC_NextAction__FP14ActionIterator Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00004a ........ ........ ExPPC_PopStackFrame__FP12ThrowContextP15MWExceptionInfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000268 ........ ........ ExPPC_UnwindStack__FP12ThrowContextP15MWExceptionInfoPv Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000046 ........ ........ ExPPC_DeletePointerCond_32__FP12ThrowContextPC23ex_deletepointercond_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00004e ........ ........ ExPPC_DeletePointerCond__FP12ThrowContextPC20ex_deletepointercond Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000026 ........ ........ ExPPC_DeletePointer_32__FP12ThrowContextPC19ex_deletepointer_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00002a ........ ........ ExPPC_DeletePointer__FP12ThrowContextPC16ex_deletepointer Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000058 ........ ........ ExPPC_DestroyMemberArray_32__FP12ThrowContextPC24ex_destroymemberarray_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00005c ........ ........ ExPPC_DestroyMemberArray__FP12ThrowContextPC21ex_destroymemberarray Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00004a ........ ........ ExPPC_DestroyMemberCond_32__FP12ThrowContextPC23ex_destroymembercond_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000052 ........ ........ ExPPC_DestroyMemberCond__FP12ThrowContextPC20ex_destroymembercond Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00006e ........ ........ ExPPC_DestroyVLA__FP12ThrowContextPC13ex_destroyvla Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00004c ........ ........ ExPPC_DestroyBaseVTT__FP12ThrowContextPC17ex_destroybasevtt Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00002c ........ ........ ExPPC_DestroyMember_32__FP12ThrowContextPC19ex_destroymember_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000030 ........ ........ ExPPC_DestroyMember__FP12ThrowContextPC16ex_destroymember Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00002c ........ ........ ExPPC_DestroyBase_32__FP12ThrowContextPC19ex_destroymember_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000030 ........ ........ ExPPC_DestroyBase__FP12ThrowContextPC16ex_destroymember Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000040 ........ ........ ExPPC_DestroyLocalArray_32__FP12ThrowContextPC23ex_destroylocalarray_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000042 ........ ........ ExPPC_DestroyLocalArray__FP12ThrowContextPC20ex_destroylocalarray Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000028 ........ ........ ExPPC_DestroyLocalPointer_32__FP12ThrowContextPC25ex_destroylocalpointer_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00002c ........ ........ ExPPC_DestroyLocalPointer__FP12ThrowContextPC22ex_destroylocalpointer Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000038 ........ ........ ExPPC_DestroyLocalCond_32__FP12ThrowContextPC22ex_destroylocalcond_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00003e ........ ........ ExPPC_DestroyLocalCond__FP12ThrowContextPC19ex_destroylocalcond Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000014 ........ ........ ExPPC_DestroyLocal_32__FP12ThrowContextPC18ex_destroylocal_32 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000016 ........ ........ ExPPC_DestroyLocal__FP12ThrowContextPC15ex_destroylocal Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000044 ........ ........ ExPPC_IsInSpecification__FPcP16ex_specification Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 0000aa ........ ........ __unexpected Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000024 ........ ........ __dt__Q23std13bad_exceptionFv Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ __ct__Q23std13bad_exceptionFv Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000022 ........ ........ ExPPC_LongJump__FP12ThrowContextPvPv Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000046 ........ ........ ExPPC_HandleUnexpected__FP12ThrowContextP15MWExceptionInfoP16ex_specification Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000238 ........ ........ ExPPC_ThrowHandler__FP12ThrowContext Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000028 ........ ........ __as__15MWExceptionInfoFRC15MWExceptionInfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000052 ........ ........ __throw Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00001c ........ ........ __end__catch Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000086 ........ ........ __uncaught_exception_helper__FP12ThrowContext Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 000028 ........ ........ __uncaught_exception Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000a ........ ........ what__Q23std13bad_exceptionCFv Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000ce2 000000 40002ce2 00001ce2 1 .text.1683 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000ce2 000008 40002ce2 00001ce2 1 .text Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00004a ........ ........ __save_gpr Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_14 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_14 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_15 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_15 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_16 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_16 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_17 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_17 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_18 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_18 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_19 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_19 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_20 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_20 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_21 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_21 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_22 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_22 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_23 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_23 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_24 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_24 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_25 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_25 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_26 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_26 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_27 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_27 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_28 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_28 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_29 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_29 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_30 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_30 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _savegpr_31 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _save32gpr_31 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00004a ........ ........ __restore_gpr Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_14 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_14 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_15 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_15 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_16 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_16 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_17 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_17 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_18 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_18 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_19 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_19 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_20 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_20 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_21 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_21 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_22 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_22 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_23 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_23 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_24 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_24 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_25 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_25 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_26 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_26 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_27 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_27 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_28 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_28 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_29 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_29 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_30 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_30 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _restgpr_31 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ _rest32gpr_31 Runtime.PPCEABI.VS.UC.a runtime.o
00000ce2 000008 40002ce2 00001ce2 2 __restore_frame_and_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ __finish_restore_frame_and_exit2 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000a ........ ........ __restore_gpr_31_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ __finish_restore_frame_and_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_30_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_29_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_28_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_27_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_26_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000a ........ ........ __restore_gpr_25_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_24_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_23_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_22_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_21_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_20_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_19_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_18_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_17_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_16_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_15_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000008 ........ ........ __restore_gpr_14_exit Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000000 ........ ........ __save_lr Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_31 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_30 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_29 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_28 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_27 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_26 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_25 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_24 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_23 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_22 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_21 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_20 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_19 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_18 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_17 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_16 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_15 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00000c ........ ........ __create_frame_and_save_gpr_14 Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 0000c4 ........ ........ __div2u Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 000108 ........ ........ __div2i Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 0000ba ........ ........ __mod2u Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 0000e2 ........ ........ __mod2i Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00001a ........ ........ __shl2i Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00001a ........ ........ __shr2u Runtime.PPCEABI.VS.UC.a runtime.o
UNUSED 00001c ........ ........ __shr2i Runtime.PPCEABI.VS.UC.a runtime.o
00000cea 000000 40002cea 00001cea 1 .text.205 Runtime.PPCEABI.VS.UC.a runtime.o
00000cea 000050 40002cea 00001cea 1 .text Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000cea 00002e 40002cea 00001cea 2 __init_cpp_exceptions Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000d18 000022 40002d18 00001d18 2 __fini_cpp_exceptions Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
.rodata section layout
00000000 00000c 40002d40 00001d40 1 .rodata __ppc_eabi_init.o
00000000 00000c 40002d40 00001d40 4 @22 __ppc_eabi_init.o
.ctors section layout
00000000 000000 40002d4c 00001d4c 1 .ctors$00 Linker Generated Symbol File
00000000 000000 40002d4c 00001d4c 4 _ctors Linker Generated Symbol File
00000000 000004 40002d4c 00001d4c 1 .ctors$10 Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000000 000004 40002d4c 00001d4c 4 __init_cpp_exceptions_reference Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000004 000004 40002d50 00001d50 1 .ctors$99 Linker Generated Symbol File
00000004 000004 40002d50 00001d50 4 _ctors$99 Linker Generated Symbol File
.dtors section layout
00000000 000000 40002d54 00001d54 1 .dtors$00 Linker Generated Symbol File
00000000 000000 40002d54 00001d54 4 _dtors Linker Generated Symbol File
00000000 000004 40002d54 00001d54 1 .dtors$15 Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000000 000004 40002d54 00001d54 4 __fini_cpp_exceptions_reference Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000004 000004 40002d58 00001d58 1 .dtors$99 Linker Generated Symbol File
00000004 000004 40002d58 00001d58 4 _dtors$99 Linker Generated Symbol File
extab section layout
00000000 000008 40002d5c 00001d5c 1 extab main.o
00000000 000008 40002d5c 00001d5c 4 @101 main.o
00000008 000008 40002d64 00001d64 1 extab Exceptions.o
00000008 000008 40002d64 00001d64 4 @5 Exceptions.o
00000010 000008 40002d6c 00001d6c 1 extab IntcInterrupts.o
00000010 000008 40002d6c 00001d6c 4 @12 IntcInterrupts.o
extabindex section layout
.__uninitialized_intc_handlertable section layout
.data section layout
.sdata section layout
00000000 000004 40003000 00001dc8 1 .sdata main.o
00000000 000004 40003000 00001dc8 4 Data_bufTotalNum main.o
00000004 000004 40003008 00001dd0 8 *fill*
00000008 000004 40003008 00001dd0 1 .sdata Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
00000008 000004 40003008 00001dd0 4 fragmentID Runtime.PPCEABI.VS.UC.a __init_cpp_exceptions.o
.sbss section layout
00000000 000034 40003010 00001dd8 1 .sbss main.o
00000000 000004 40003010 00001dd8 4 num main.o
00000004 000004 40003014 00001ddc 4 CANA_i main.o
00000008 000004 40003018 00001de0 4 CANAlen main.o
0000000c 000004 4000301c 00001de4 4 CANAdummy main.o
00000010 000003 40003020 00001de8 4 FLAG_ThisBlockCanntErase main.o
UNUSED 000001 ........ ........ FLAG_BiginToProgramme main.o
00000014 000004 40003024 00001dec 4 Data_bufCount main.o
00000018 000004 40003028 00001df0 4 FlashStartAddr main.o
0000001c 000004 4000302c 00001df4 4 PageTotalNum main.o
00000020 000004 40003030 00001df8 4 PageCounter main.o
00000024 000004 40003034 00001dfc 4 PageInterCount main.o
00000028 000004 40003038 00001e00 4 one_fourth_Page_32b main.o
0000002c 000004 4000303c 00001e04 4 ECCErrPageAddr main.o
00000030 000004 40003040 00001e08 4 sp_FlashPageAddr32 main.o
.sdata2 section layout
.sbss2 section layout
.bss section layout
00000000 000400 40003048 00001dd8 1 .bss main.o
00000000 000400 40003048 00001dd8 8 Data_buf main.o
00000400 00000c 40003448 000021d8 1 .bss Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000400 00000c 40003448 000021d8 4 fragmentinfo Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
00000000 00000c 40002d74 00001dc8 4 @102 main.o
0000000c 00000c 40002d80 00001dc8 4 @6 Exceptions.o
00000018 00000c 40002d8c 00001dc8 4 @13 IntcInterrupts.o
00000024 000030 40002d98 00001dc8 4 _eti_init_info Linker Generated Symbol File
UNUSED 00000c ........ ........ @224 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @308 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @409 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @435 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @807 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @860 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @871 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @916 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @964 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @971 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1028 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1104 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1119 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1147 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1421 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1426 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1532 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @1539 Runtime.PPCEABI.VS.UC.a ExceptionPPC.o
UNUSED 00000c ........ ........ @47 __start.o
UNUSED 00000c ........ ........ @57 __start.o
Memory map:
Starting Size File S-Record
address Offset Line
.init 40000000 00000000 000001a0 0
.init_vle 40000000 000000e8 000001a0 2
.__exception_handlers 40001000 000000a8 00000290 14
.text 40002000 00000000 00001000 0
.text_vle 40002000 00000d3c 00001000 23
.rodata 40002d40 0000000c 00001d40 193
.ctors 40002d4c 00000008 00001d4c 194
.dtors 40002d54 00000008 00001d54 195
extab 40002d5c 00000018 00001d5c 196
extabindex 40002d74 00000054 00001d74 198
.__uninitialized_intc_handlertable 40003000 00000000 00001dd0 0
.data 40003000 00000000 00001dc8 0
.sdata 40003000 0000000c 00001dc8 203
.sbss 40003010 00000034 00001dd8 0
.sdata2 40003044 00000000 00001dd8 0
.sbss2 40003044 00000000 00001dd8 0
.bss 40003048 0000040c 00001dd8 0
.PPC.EMB.apuinfo 000038e4 00000000 000056c0 0
.debug_abbrev 0000015d 00001dd8
.debug_info 00001109 00001f35
.debug_line 000017c7 0000303e
.debug_loc 00000174 00004805
.debug_pubnames 00000349 00004979
Linker generated symbols:
EXCEPTION_HANDLERS 40001000
L2SRAM_LOCATION 40003004
_f_init 40000000
_f_init_rom 40000000
_e_init 40000000
_f_init_vle 40000000
_f_init_vle_rom 40000000
_e_init_vle 400000e8
_f___exception_handlers 40001000
_f___exception_handlers_rom 40001000
_e___exception_handlers 400010a8
_f_text 40002000
_f_text_rom 40002000
_e_text 40002000
_f_text_vle 40002000
_f_text_vle_rom 40002000
_e_text_vle 40002d3c
_f_rodata 40002d40
_f_rodata_rom 40002d40
_e_rodata 40002d4c
_f_ctors 40002d4c
_f_ctors_rom 40002d4c
_e_ctors 40002d54
_f_dtors 40002d54
_f_dtors_rom 40002d54
_e_dtors 40002d5c
_fextab 40002d5c
_fextab_rom 40002d5c
_eextab 40002d74
_fextabindex 40002d74
_fextabindex_rom 40002d74
_eextabindex 40002dc8
_f___uninitialized_intc_handlertable 40003000
_e___uninitialized_intc_handlertable 40003000
_f_data 40003000
_f_data_rom 40003000
_e_data 40003000
_f_sdata 40003000
_f_sdata_rom 40003000
_e_sdata 4000300c
_f_sbss 40003010
_e_sbss 40003044
_f_sdata2 40003044
_f_sdata2_rom 40003048
_e_sdata2 40003044
_f_sbss2 40003044
_e_sbss2 40003044
_f_bss 40003048
_e_bss 40003454
_stack_addr 40006000
_stack_end 40005000
_heap_addr 40004000
_heap_end 40005000
_nbfunctions 00000011
SIZEOF_HEADERS 000001a0
_SDA_BASE_ 4000b000
_SDA2_BASE_ 4000b044
_ABS_SDA_BASE_ 4000b000
_ABS_SDA2_BASE_ 4000b044
Now my program can not run, but the example can be used, the same method to modify the start. C.The program is primarily a boot file that runs in RAM.My question is why to modify int_data,andmy program can not run.
Original Attachment has been moved to: MPC5534_DEBUG.lcf.zip
Original Attachment has been moved to: __ppc_eabi_init.c.zip
Original Attachment has been moved to: __start.c.zip
Please follow https://community.nxp.com/thread/443190
