problem about adc_pal_MPC5744P
supra0309
Excuse me, what should I do to make this example run successful. I need to print string in console. Does it need any inputs or just need to connect to the PC and debug? Is there any settings need to do? Thanks.
Xantia
petervlna
I just compiled the example file without any further configuration needed with no errors.
It should be simple, just connect the board to PC and run it.
I did not find any setting which you should set, except RTOS (which is optional)
regards,
Peter
supra0309
Thanks for your reply. I have another question, when after run it what does the result should be?
Xantia
petervlna
Hmm,
You mean ADC results.
It will depend on voltage on measured analog pin.
regards,
Peter
supra0309
Thanks for your answer. There's another problem. In this example, I find "extern uint16_t adc_pal1_Results00[(3u) * (2u)]; " and "resVolts = ((float) adc_pal1_Results00[idx] / adcMax) * 5". But I can't understand why uses these. Could you help?
Xantia
petervlna
Where is the example from?
Could you link it / share it here?
best regards,
Peter
supra0309
Sure, I can show you where's it.
Xantia
