mpc5775k how to entry debug mode?
lyj
when  assert  reset ,the chip can't entry debug mode by setting the OCR[DR],OCR[WKUP]
whoam
Hi yj L,
have you found a solution for the problem?
I'm also having trouble to get the 5775K into debug mode and read/write with Nexus after entering debug mode.
whoam
petervlna
When reset is assert micro cannot enter debug mode.
Peter
petervlna
Are you creating you own JTAG debug tool?
Did you follow AN4365?
https://cache.nxp.com/docs/en/application-note/AN4365.pdf?fsrch=1&sr=1&pageNum=1
Peter
lyj
yes
When reset is assert ,micro  need waite for a long time and shift-ir "211"(bypass) before Set the OCR[DR] and OCR[WKUP] bits.
after entering debug mode,read-write sram will go wrong
