Hello all,
I'm using CW2.9. This IDE is creating a .mot file. I need to convert it to .hex file. Is there any nxp tool that will convert this to .hex file.
Thanks in advance,
Raju
Solved! Go to Solution.
Hi, I have found following discussion I believe shows a solution:
https://community.nxp.com/thread/75720
Let me know if it helps or not
One more thing what I understood was, One cannot convert the .mot or .hex to binary. Instead they can convert the .elf to binary and then binary to hex or mot. Anyway thanks for your help.
Raju
Hi David,
Sorry to interrupt.
In fact, I successfully converted the mot file to hex file. But I want convert my mot to binary first and then binary to hex but the command prompt is always showing unable to recognize the format of the input file.
Can you suggest what I need to be done to get it successfully run.
Raju
Hi David,
Thanks for your swift response. It had been used successfully. Thanks a lot
Raju
