init      Linker Generated Symbol File
Search instead for
在rom.map没有这个是为什么?
Boot Assist Module (BAM) with FlexCAN MPC5534
Hello !
I need to use the Boot Assist Module to boot an application from FlexCan bust to internal SRAM.
 I  modify the start.c,but my rom.mot is not use.
Can help me with a example code? Just I have to modify the Linker Files?
Thank you very much for your time!
Please do not duplicate the threads. Follow https://community.nxp.com/thread/443190
Hi, I met a problem when I was using mpc5634, and I generated ram.mot files on the way you provided, but my application didn't run on ram! What's the reason? Can help me? Thank you for your。
at first, could you please write your question in English? Second, the question does not make any sense to me. Could you please clarify it?
Martin
