how to use the ADC of Temperature Sensor
yinlei
I would like to use the ADC internal temperature sensor to measure the chip temperature, but I will not be configured, how to get the value of K. Can you give a reference example?
Tags (2)
davidtosenovjan
Temperature sensor seems to be the same implementation as on MPC5744P, thus following example could be useful for you:
https://community.nxp.com/docs/DOC-104657
davidtosenovjan
yinlei
Yes, I saw the example, but I do not know where the values of K1, k2,k3,k4 look, where is the text flash in the reference manual, how to get
davidtosenovjan
It is located in UTEST memory:
davidtosenovjan
Could you specify used MCU part number? Thanks
yinlei
the MCU  is 5775
yinlei
If there is an example, that's the bestI want to learn its configuration
