I have a problem in got can error type,
I had enable CAN error reg, and enable CAN modules.
such as, I creat NO-ACK error. then the error irq is got.however when i read ESR1, ERRINT is SET,but ACKERR is zero.
so.what should i do to get useful CAN error type.
thanks for you read.
