eMIOS PWM channel setting for 5746R
supra0309
I'm testing PWM function on 5746R. In component PWM mode, there were some trouble occur. Channel's description said "channel only support from 8-23". but when I did it, I found only channel 8, 16, 22, 23 can be used. What should I do to resolve it?
Xantia
petervlna
Regarding reference manual all modes are available for all channel.
So this is issue of configuration tool you are using.
Could you share more details on the tool?
Are you using latest version of it?
regards,
Peter
supra0309
Here's the update check results.
Xantia
petervlna
In the post header you are using MPC5746R but you have SDK for S32R274?
Am I missing something?
Which is your device?
regards,
Peter
supra0309
I'm using MPC5746R.
Xantia
