I am having some problems with the Quiescent current and I am thinking that maybe I have configured floating pins wrong.
Solved! Go to Solution.
For unused digital pins, it is recommended that software disable both the input buffers and the output buffers of the pads in the Pad Control Register for the pins. In addition, the weak pull-down device should be enabled.
Many thanks! I'll try to change the registers affected.
Hi David,
Could you confirm that this statement is generally applicable as well in a 5777C cobra CPU? Thanks.
Yes, for MPC5777C as well.
