Where to purchase MPC5746R Trace Adapter (TA) part number MPCLFDBGK46RT4S2A ?
ragulankandiah
Hi there,
I am working on a MPC5746R based design. It looks like this does not have the Nexus support. To get nexus port, I have to use the Trace Adapter with 292 pin BGA emulation device (ED) part number MPCLFDBGK46RT4S2A.
Is the above statement correct? If you where can I purchase MPCLFDBGK46RT4S2A? or I have to make my own TA with ED? If I have to make my own TA, where can I purchase the ED?
Thanks.
davidtosenovjan
I have found it already, the part number is slightly different:
https://www.nxp.com/part/LFDBGK46RT4S2A?lang_cd=en#Buy_Options
davidtosenovjan
Could you share with us where did you find such part number? I haven't found any reference to MPCLFDBGK46RT4S2A.
davidtosenovjan
ragulankandiah
Thank you for your reply. This is the part I will need. When will it be available for purchase (order status is indicated as pending stock)?
davidtosenovjan
You can order there, apparently it is not available immediately or it is available in external stock. It may be some delay there.
