I have the samples SPC5643LFK0MLQ1, but I can find ordering information in datasheet(MPC5643L, Rev. 9, 6/2013) about SPC5643LF2MLQ1 instead of SPC5643LFK0MLQ1.
What's the difference between SPC5643LFK0MLQ1 and SPC5643LF2MLQ1?
I can not find any information about the part number SPC5643LF2MLQ1.
Solved! Go to Solution.
Not sure what exactly you have on your mind. You may see errata sheet and product change notification:
https://www.nxp.com/docs/en/errata/MPC5643L_2N89D-0N18H.pdf
https://www.nxp.com/docs/en/product-change-notice/PCN16247.htm
Ordering information then under tab 'Buy/Parametrics':
SPC5643LFK0MLQ1 is mask 0N18H
SPC5643LF2MLQ1 is mask 2N89D
Both masks are basically the same and differs only in manufacturing facility. Both are revision 3.1 and shares the same errata sheet.
Hi David,
Do you have some document descripbing the details about the case, just like ordering information about different product for order?
I mean , that is , which product / part we should choose for order?
Hi David ,
Product change notice is what I need. Thank you very much.
