What happen in LIN protocol if Slave is not present during the data sending by master.
Search instead for
anishchoudhary
I configure a ID  in BIDR register for slave in master mode for transmitting data from master to slave but with there no one slave have that same id that I am transmitting by master, then what will happen? Is that goes in infinite waiting state till new frame is not coming or same slave is not found.
PetrS
if Master is sending a data then nothing happen. Master transfers full frame, sets DTF flag and goes to IDLE.
Then user can generate another frame. Master is always sending a header. If Master is transmitter then it is sending a data too. If Master is receiver, then after sending a header it waits for data from Slave.
BR, Petr
