Use of Semaphore(shared memory) in ISR
amey_murkute
Hi all,
      I am using MPC5777C controller for my project & want to use shared memory. I have to read EQADC value at every 32uS in Core 0 & pass the same value to core 1 for my further computation. So is it possible to lock and unlock the core in ISR? any leads would be helpful.
thanks & Regards,
Amey
davidtosenovjan
Hi, here you may find a example code for using of semaphores:
Example MPC5775K Semaphores S32DS_1.0
Even though prepared for different device, usage of SEMA module is similar.
