Usage of Qadc in mpc5777c
2,177 次查看
vignesh_v
Is there any example to use Qadc module in mpc5777c for example to read analog pin ANA23
标签 (1)
标记 (3)
4 回复数
2,063 次查看
vignesh_v
what is ADC resolution been given and same example can be modified for  can it be used for eQADC.A also? cuz im using eQADC A.
2,063 次查看
petervlna
You can check out our example repository on community:
Example MPC5777C-eQADC_Simple GHS714
https://community.nxp.com/docs/DOC-329623
regards,
Peter
2,063 次查看
vignesh_v
My objective is to read analog pin when requested by the application and report the voltage.
2,063 次查看
vignesh_v
In the example 2 channel are used what if i want to do for one channel and for even that EOQ is set ? Can u pl explain how it's been done..
