I am using S32DS working on MPC5748G.
I wrote a .h file,and include this.h file in another C file. They are in the same directory.
But it shows the problem: No such file or directory.
Excuse me, how to solve this problem?
Thanks and best grade,
lixu
check where those files are stored in your PC and be sure a proper path to this folder is added within project properties .
BR, Petr
I should not have added a path to the project property.
Another problem is that when I use the project in "example", when I open it in the hard drive, the .c, .h and other files under the project folder are not displayed, and there are no files in it. What is the reason for this?
Lixu
modify a ProcessorExpert.pe file as suggested e.g. in https://community.nxp.com/t5/S32-Design-Studio/s32k-example-project-accessing-files-on-system-direct...
BR, Petr
