The eTimer PWM of MPC5744must be generated using the interrupt
pingli
The eTimer PWM of MPC5744must be generated using the interrupt?
petervlna
Could you please explain your question more closely?
from your description I am not able to recognize the issue/requirements.
Peter
pingli
I want to generate PWM output with eTimer, but I don't use interrupts, so it can be implemented
