TGN2-0054-30-36 Motor Data sheet
alimeraj
Can someone please help me with the TGN2-0054-30-36 motor data sheet. This motor is used in  MCSPTR2A5775E development kit. I have 2 of these kit however I cant find the motor data sheet anywhere. I need the motor parameters to design my control system.
Ali
lukaszadrapa
See please attachment, that's what I got from them.
Hope it helps.
Lukas
lukaszadrapa
alimeraj
Hi Lukas,
Thanks for sending the links.
I have one more motor that came with NXP kit which is bit different to TGN2-0054-30-36 and I cant seems to find the motor parameter for TGT2-0032-30-24 in the links you sent me. could you please point me where I can find the motor parameters for this motor.
Ali
lukaszadrapa
Hi Ali,
I can't find details on their site too. I have only these numbers for the motor:
0.32Nm, 30V, 5.2A, 3000rpm
If it is not sufficient, please send them an email and request more details: info@tgdrives.cz
Lukas
alimeraj
Thanks for looking Lukas,
I need inductance, resistance and BEMF value for my control. I don't have RLC meter otherwise I would have measure it. I tried to contact tgdrive but they never contacted back. I was thinking if you guys have any direct contact with them since your kits have their motors?
Ali
lukaszadrapa
Hmm, I do not have direct contact but let me try to ask them. Maybe I will have more luck.
Lukas
alimeraj
Thanks Lukas, really appreciated.
lukaszadrapa
Hope it helps.
Lukas
alimeraj
Hi Lukas,
This is great, this is exactly what I was looking for.
Thank you very much.
Kind Regards,
Ali
