Some possible bugs in S32_SDK_MPC574xx_RTM_1.0.0
shanix
Hello
When I use the S32_SDK_MPC574xx_RTM_1.0.0 on the MPC5748G, I found some code in SDK that may be problematical and would like to have it confirmed. Thanks.
PetrS
you have quite old SDK version, I can recommend to use the latest one, below is snippet from RTM 3.0.3
Yes, setting of WRNEN is possible in Freeze mode only.
A driver enable error interrupts if you install error callback using FLEXCAN_DRV_InstallErrorCallback, and Freeze mode is entered in it.
BR, Petr
PetrS
BR, Petr
shanix
Thanks! Your reply is very useful. Maybe I need to migrate to the new verison SDK.
shanix
