SPI Communication between MPC5775K and MR2001V
maheshsubramani
We are interfacing MPC5775K with MR2001V (VCO) by SPI
The Write commands are sent as expected  . But doing a read does not read the set variables values
Enclosed is SPI code.
  1. Write message was done  to set identification key for VCO (i.e.) 10110000 to identification key and the S1 register
  2. read was done for 0x02 VCO S1 State Machine Register, after a write. But read returned 0
Original Attachment has been moved to: spi_rfs.c.zip
martin_kovar
at first, please look at this example which shows, how to correctly set SPI as a master/slave and how to communicate between these two nodes.
MPC5775K SPI
Martin
