SPC5643L 的pwmx输出
Search instead for
SPC5643L 的pwmx输出
steven_zhang
Contributor V
要怎样才能配置SPC5643L 的pwmx pin 输出pwm,能和PWMA 或PWMB 同时输出PWM信号吗,频率会是一样吗。
petervlna
You can use PWMX channel for generating of PWM signal.
Have in mind that VAL0 is also used as Half reload trigger when half reload strategy is used.
Peter
