S32R SecureBoot only work after a sw reset
stephen11
hi,
i’m developing the secure boot function on S32R294.
the test result is that when i power up directly, the secure boot is failed. then I trigger a warm reset the result become successful. do you know the reason for that?
Tags (2)
nxf46852
Issue has been solved . The conclusion is : ZF code operation impact secure boot behavior, we suggest they switch to sequential boot mode before performing the secure boot enablement procedure.
In this mode, from customer feedback issue fixed.
petervlna
I have contact our RADAR team and ask for help.
I will feedback you ASAP.
Peter
stephen11
Hi Peter,
thanks, looking forward to your feedback.
Stephen
