hello
I recently found that my S32 Design Studio PA license has expired. I am trying to reactivate it, but it is not working.
Activate Code : 7B54-8F8F-155B-0D0A
I recently changed the physical HDD on my computer, and it seems that reactivation is not working. The return is also not functioning. Is this due to the change in the HDD?
Yes, that is correct. We have granted you v2.1 license.
I overlooked the request for PA 2017.
Please use the link below:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-E2002-0
In license tab you can get license.
Peter
Hello @petervlna
I am already aware of the information you provided. I want to renew the license as it has expired, but the license date is not getting updated. Even when I try to return it, an error occurs, and the return process is not successful.
Ok. We manually extended your license.
Use the same activation code as you posted above it should extend your license.
Peter
dear peter
Problem is Clear
Thx
Looking at your account you manage to extend it at 1.1.2024
New expiry date is 2027
your installation code is : 38D3-B9E0-6D17-8947
Peter
Dear Peter
When you enter the activation code 38D3-B9E0-6D17-8947, it prompts 'Your Software Activation Code is for another feature. Do you want to return?' If you press 'Yes,' the code 38D3-B9E0-6D17-8947 gets deactivated. If you press 'No,' nothing happens
Hi, @cskwon ,
Please can you try once again. And let us know if it is working or not.
Thank you. Best regards,
- Mehul Patel
The error occurred just like the reply I wrote above, I attached a picture to the original question
