I am using mpc5748g MCU.
I will use the EEPROM which is inside the MCU.
How many milliseconds does the EEPROM write and read take?
thanks,
EEPROM internal memory is not present on 5748G device.
But there are flash memory block well suitable for EEPROM emulation.
Some timing you may find in EEPROM emulation driver user manual (attached), Tables 5-4, 5-5 and 5-6.
Use case for MPC5775K and scale according used frequency and result should be similar. Unfortunately there is no timing explicitly specified for MPC5748G.
