REACM (reaction module) API in MPC5644A
1,035 次查看
turgay_kale
I want to use the reaction module (REACM) in MPC5644A. As I have searched the documents and possible existing utility functions (driver) and API's to use the REACM for MPC5644A, I couldn't find any source except the MPC5644A microcontroller reference manual. All the sources I've found is about REACM2. Is there any example utility functions (driver) and API source code to use REACM in MPC5644A?
Thank you for your help.
Turgay Kale
828 次查看
davidtosenovjan
Hi, there is no API or driver. I can sent you example code with description.
Hi, please create new case according to following procedure with reference to this thread in the subject:
https://community.nxp.com/docs/DOC-329745
I am sending you example code directly as I don't want to share it here publicly.
829 次查看
davidtosenovjan
828 次查看
turgay_kale
Dear David hi, thank you for your help. The support case number is 00252374.
