RDK-S32R274,the demo program often fails -- RSDK_SPT_RET_ERR_DMA
chenrensong1
It often error occurs when I run RSDK_demo,the error message is “RSDK_SPT_RET_ERR_DMA”.
I did not change the source code,what is the reason for this error?how to solve it?
I need help,thanks
petervlna
Could you share more details?
We need more information how this issue can be reproduced. Could you post some screenshots also?
Peter
petervlna
Peter
xiangliping
in S32R294,i also met this problem.i foun that in DMA_ERR_STATUS register,this value is 0xa0.CS_AHB_ERR and PDMA_AHB_ERR occurred.in which case,it will cause thses two errors.
chenrensong1
This problem has been solved,I used eeprom by mistake.
thinks for your attention
iceice
Why is this error related to eeprom
