RDK-S32R274,the demo program often fails -- RSDK_SPT_RET_ERR_DMA
1,481件の閲覧回数
chenrensong1
It often error occurs when I run RSDK_demo,the error message is “RSDK_SPT_RET_ERR_DMA”.
I did not change the source code,what is the reason for this error?how to solve it?
I need help,thanks
1,472件の閲覧回数
petervlna
Could you share more details?
We need more information how this issue can be reproduced. Could you post some screenshots also?
Peter
4 返答(返信)
1,473件の閲覧回数
petervlna
Peter
1,258件の閲覧回数
xiangliping
in S32R294,i also met this problem.i foun that in DMA_ERR_STATUS register,this value is 0xa0.CS_AHB_ERR and PDMA_AHB_ERR occurred.in which case,it will cause thses two errors.
1,457件の閲覧回数
chenrensong1
This problem has been solved,I used eeprom by mistake.
thinks for your attention
547件の閲覧回数
iceice
Why is this error related to eeprom
