Question of MPC5777C’s ADC input current
2,417 次查看
Luke_Chun
Dear Team
Could you check my question of MPC5777C’s ADC input current?
Could you let me know about the minimum input current(not ADC module's power consumption) on the ADC’s pin for the measurement?
Because I wish to know the minimum input current for the calculation of ADC pin’s series resistor value.
If you have ADC H/W guidance, please provide it.
Thank you.
2,281 次查看
davidtosenovjan
Current limiting resistor values should be based on IINJA value what is 5mA for MPC5777C device.
I don’t have a guidance but I can share excel calculator showing influence external component of ADC input on conversion accuracy – note that it is related to eQADC module only (document prepared for MPC55xx devices but applicable for MPC5777C eQADC module as well as this module is backward compatible).
2,282 次查看
davidtosenovjan
