Hello everyone,
I would like to ask a question. Could you inform me about that whether there is a way to enable core regulater apart from DCF records?
Solved! Go to Solution.
As you can see, these are enabled by default
Dear @davidtosenovjan
Thank you for your kind response.
What if I would like to disable? Is there any way except DCF records?
No, I think, it is not.
