Hi I am using S32 DS and PE multilink universal debugger for MPC5777c-416DS with MPC 57xx mother board...when am running the code through debug configurations one popup window is coming showing...NO SOURCE AVAILABLE FOR 0x800400
Solved! Go to Solution.
This means that you are missing source code. For example if you executed some library function where is missing source code.
Or it could be refresh issue.
Try to rebuild whole project and make sure you have all source files which are required.
best regards,
Peter
best regards,
Peter
