MPC5777M question about BAF_0N50N.s3 file
underdangerous
There is a question that has been bothering me for a long time. May I ask if the data part in the BAF_0N50N. s3 file can be converted into assembly code through disassembly? The results of my attempt to use the objdump instruction and IDA pro disassembly were different from what was expected. If possible, could you please inform us of the conversion method? THX.
petervlna
I am not really sure what you are referring to.
Have a look at following thread:
https://community.nxp.com/t5/Kinetis-Microcontrollers/SREC-Decompilation/td-p/776007
Peter
jiri_kral
What is your objdump command for disassembling s-record? Did you specify correct endian and architecture?
