MPC5777C two eqadc module can work at the same time?
3,364 次查看
Alex5080
MPC5777C has two hardware eqadc module. To  speed sample time and collect data. I hope that  two moduel can work at the same time in parallel.   would you help to provide reference example?
6 回复数
3,288 次查看
Alex5080
anyone can help to check this case?
3,306 次查看
Alex5080
hello,  I find that those example only run one eQADC module(2 ADC units).   would you please share the example which run 2 eQADC modules(4 ADC units).?
Attached file is our file,  it canot work well.    we need close 1 eQADC modules, then run another  eQADC moduels. .we find these 2 eQADC moduels doesn't work at the same time.
3,238 次查看
davidtosenovjan
3,290 次查看
davidtosenovjan
I am attaching previous version (v0_2) of the example where I have been using eQADC_B, v0_3 has been changed to eQADC_A. You could combine it together.
标记 (1)
3,278 次查看
Alex5080
after combined v02/v03,  two resultis is zero.
3,352 次查看
davidtosenovjan
There are 2 eQADC modules on this device, both consists of 2 ADC units => you may convert 4 channels in parallel, but it must be different channels.
Example codes you may find here, browse for eQADC:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5-software-example-list/ta-p/1102445
