MPC5777C SRAM
MPC5777C SRAM
dreamtea81125
HI NXP
I have a problem about SRAM.
It seem I can read the SRAM but can't write.
Can you check the code for me ?
Thank you very much.
dreamtea81125
HI Peter,
Thank you for your reply.
I solved this problem.Thank you.
1620773328
Hi MingWei,
I am using your example to test external SRAM on MPC5777CEVB,but it does work as expected.
How to improve this example? Thanks in advance!!
Jinus
petervlna
Please have a look at our reference example:
https://community.nxp.com/docs/DOC-335543
 I hope it will give you a clue how it works.
regards,
Peter
