MPC5777C IPC shared memory
ソリューションへジャンプ
2,061件の閲覧回数
San_96
What are the chapters in MPC5777C describe about data sharing between two Core processors ?
2,037件の閲覧回数
lukaszadrapa
there's no such chapter. Both cores have an access to whole memory map, so you can use any part of RAM memory as shared memory. I can only recommend to configure this shared memory as cache inhibited - this can be done using MMU. And to ensure data coherency, you can use semaphores (SEMA4 module).
Lukas
2,038件の閲覧回数
lukaszadrapa
Lukas
