Hi All,
I am using MPC5777C controller with S32DS IDE,i initialized the module for SAIC,when i try to check
i facing following issue
Signal at the pin is loading
I am not getting any update in status register reading edge detection.
I considered first 8 as EMIOS_0:0_7 channel,next 8 as EMIOS_1:0_7 and next 8 as EMIOS_0:16_23.
i tried by disabling glich filter also but it is not working.
please suggest some sample code or solution.
Thank&Regards,
Naidu
