MPC5748g enet_rmii_udp example
2,069件の閲覧回数
caigangwu
Hello!
I'm use the enet_rmii_udp example  of mpc5748g  from S32,but when try to send and receive udp packets simultaneously,found that  the register of receive buffer do not update unless hardware initialization.Does anyone have faced this problem? need your help!!!THANKS much.
2 返答(返信)
1,697件の閲覧回数
hjianzoo
ME TOO! ARE YOU SOLVED IT?
1,697件の閲覧回数
961271210
Hello
I am trying to debug your project, but there are some problem and the serial port cannot output what I send to board by ethernet. I wonder if I need to do some changes before debugging this project?
THanks,
Jupeng
